Ok boys and girls.. For the 62nd Annual US Nationals.. NHRA has pulled the HP hit that STK and SSTK will get.. So it means that people should hopefully let it rip.. Our little contest is, Guess what the number will be for STK and SSTK. The closest to it wins a custom carb cover from Steve Broadbent at SIDS SHEET METAL. Also in the event of a tie.. We are going to do a coin flip on FB LIVE VIDEO.. So pick heads or tales along with what you think the magic number will be...
Thanks and good luck. Post your pic on the thread on our FB page. www.facebook.com/wheelzupradio |
If the Seville shows up 2.10 under
Liked 574 Times in 212 Posts
Without the HP factor....someone will go 2 seconds under......did I just say that??? It will be a lower class car.. (has to be) probably a U/S type car.
Gary Hansen - SS/FA 4911, B/SA 4911 |
Liked 66 Times in 37 Posts
First K/SA in the 10'S !!!!!
72 cutlass |
Liked 460 Times in 91 Posts
O/SA 11.50 or P/SA 11.70
Bob Bender 144 O/SA 2010-2012 National Record Holder |
Liked 83 Times in 32 Posts
Liked 369 Times in 127 Posts
There was an N/SA that ran in the 11.30's last year at the Indy fall event.
I'd say the same car in P/SA will run 11.80's this year in the heat
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Wow
1.66 under in the heat ?
Liked 239 Times in 94 Posts
I think bump spot would be a better contest (.822 under Stock and .803 under SS)
I'd hate to throw out a guess if there is a new COPO Camaro coming out Tuesday rated at 310hp with an 18 to 1 compression, dual Dominator, inch lift 572. No doubt an already well-tested example would be running 3 seconds under. |
Liked 5,121 Times in 1,952 Posts
Stock, 1.65 under.
