Old 08-22-2016, 01:15 PM   #1
JP Schuster
Default Minimum Weight in Modified Class? - Super Stock
Does the 5% weight break for automatic transmissions apply to the minimum weight posted as well? i.e. if the minimum for SS/TA is 3350 lbs, can you apply the automatic trans 5% so that the actual minimum is 3185 lbs if using an automatic?
Thanks,
JP
JP Schuster is offline   Reply With Quote
