Old 06-28-2016, 08:04 AM   #1
joespanova
Liked 13 Times in 11 Posts
Default Oil capacity.......what do you run?
Wet sumps.
How much oil do you guys carry in the sump?
I have a Gen 1 style SBC and carry 6-6.5 quarts plus filter.
Moroso pan.
Old 06-28-2016, 08:17 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Oil capacity.......what do you run?
7 quart pan on my 522, 6 quart pan on my 598, both filled with Mobil 1 synthetic 10W-30 .
Old 06-28-2016, 08:41 AM   #3
joespanova
So , I'll assume 7 quarts in the 522 and 6 quarts in the 598........
Old 06-28-2016, 08:58 AM   #4
1320racer
1320racer's Avatar
yes, including filter which on the 522 is a K&P http://kandpengineering.com/ that doesn't hold much and a Wix Racing filter on the 598 that holds about 1/2 quart but soon to be replaced with a K&P also.
Old 06-28-2016, 09:08 AM   #5
joespanova
I have run 5 quarts plus filter in the past in the 355 ( 7 quart pans ) .
BUT as you know , I've had oil starvation issues and as a part of my "shotgun" approach , I was thinking of adding oil.
As of now the 355 has 6 quarts total ( includes filter ).............I'll probably add another quart.
Old 06-28-2016, 09:15 AM   #6
1320racer
1320racer's Avatar
Your oil starvation issues are not due to running up to 1 1/2 quarts shy.
Old 06-28-2016, 09:33 AM   #7
joespanova
No.........Agreed .........I doubt that myself.
I'm sure I have that figured out now BUT , I was just curious as to what levels are common.......
Old 06-28-2016, 09:40 AM   #8
cad
cad's Avatar
Liked 91 Times in 51 Posts
SBC -- 6.5 qts total in my B&B 7 qt pan with a 51061R filter.
Old 06-28-2016, 11:11 AM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,934 Times in 581 Posts
Joe,
I am running 6 qts of the 30w Lightning Racing Oil in my 350. I have a Moroso Billet oil pump and an 8 qt pan. I also run a System One filter. I have run as much as 7 qts and as low as 5 qts with no issue. If you are bracket racing I would run 7 qts.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 06-28-2016, 11:36 AM   #10
joespanova
Thanks guys.........
