Old 06-25-2016, 05:37 PM   #1
Mike V
Default MSD crank trigger problems
I freshened my SBC over the winter and now I am have a problem with my ignition system.I use a MSD crank trigger with a 6AL box and a crank trigger distributor.Before the rebuild I could only run about 34 degrees of timing, because it was hard to start.Now it fires up now matter how much timing.I have set it from 32 to 49 degrees and starts up with no problem.I changed the pickup,cable to the box,new coil, and tried 2 different ignition boxes and nothing changes.The car is also about a half second slower, but still consistent.Anyone have any idea what else to try? Thanks
Mike V is offline   Reply With Quote
Old 06-26-2016, 01:03 AM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
Default Re: MSD crank trigger problems
Distributor phased properly?
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 06-26-2016, 10:13 AM   #3
Are you absolutely certain that nothing is wrong with your harmonic balancer, and your timing pointer? Are you sure that what you have for TDC there is actually true TDC for the engine? Have you checked that since the engine was first started?
Old 06-26-2016, 08:20 PM   #4
Mike V
I found the distributor phasing was off, so I adjusted it.Still starts very easy @ 40 degrees.I also set #1 at TDC and the balancer was at TDC. May pull out this system and try an old electronic distributor just to see what happens.
Old 06-27-2016, 08:43 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
Have you put leak down check on the engine or a compression test. Sounds like you could have a ring seal issue after the freshen up. Low compression would allow the engine to crank over easier. I had a similar issue after a freshen up and the compression was so low the engine would not start after one pass.
Mike Pearson 2485 SS
Old 06-28-2016, 12:08 PM   #6
Mike V
Compression ranges from 170 -180,have not done a leak down test. Borrowing an HEI distributor and going to try that.
Old 06-29-2016, 10:47 AM   #7
randy wilson
Liked 22 Times in 22 Posts
Try a new pickup unless you already have.
don,t have one
