Old 06-14-2016, 08:57 AM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default Trans Bolt Holes 3rd Gen Camaro
I was putting the trans crossmember back in my car last night and two of the cage nuts(?) inside the frame are turning when i tighten the bolts. Anybody have this problem? The car has been around for 17 years now with lots of trans changes or engine changes that involved removing the trans crossmember, guess it just wore out the way the threads are secured in the frame. This car has been fighting me lately.
brian schuetta is offline   Reply With Quote
Old 06-14-2016, 03:08 PM   #2
brian schuetta
Default Re: Trans Bolt Holes 3rd Gen Camaro
Do i cut the floor or the side of the frame to access these nuts and weld it back up?
Old 06-14-2016, 04:52 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Maybe drill it out and put a Riv-Nut in the hole .
Old 06-14-2016, 10:08 PM   #4
Doug Domm
Liked 84 Times in 21 Posts
Maybe drill a hole on either side of the nut shoulder then plug weld it?
Doug Domm is offline   Reply With Quote
Old 06-14-2016, 10:21 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Most commercial fastener distributors have expanding insert nuts like Riv Nuts and other brands .
Most areas have a Fastenall store nearby .
Make sure you use the heavy duty style for the proper thickness of the frame , There are different types for use and gauge of metal.
Old 06-15-2016, 08:30 AM   #6
brian schuetta
Thank you for the replies. I will find the Fastenal in San Antonio. In the meantime I will look up these rev nut things and get familiar with them.
Old 06-15-2016, 11:43 AM   #7
brian schuetta
Found a Fastenal store in New Braunfels TX, they gave me a catalog and told me the Rivnut tool can be borrowed from Auto Zone. Just have to get right size nut, I think its 10 mm for the crossmember bolts.
Old 06-16-2016, 09:07 AM   #8
henrys57wagon
henrys57wagon's Avatar
I use a bolt and flat washer to install riv nuts when I don't have the correct threaded insert for my riv-tool.
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 06-16-2016, 10:51 AM   #9
Eman
Liked 133 Times in 76 Posts
Mine gave up a while ago, too many trans changes. I just drilled out and retapped the originals to a larger SAE size.
Old 06-16-2016, 03:12 PM   #10
brian schuetta
Eman were they loose in the folded sheet metal frame? Auto Zone never heard of that type of rivet gun BTW. Hope to work on it again tonight.
