Old 05-12-2016, 08:44 PM   #1
L79racer
L79racer's Avatar
Default sooty oil?
What is the cause of this? This is fresh oil with six 1/8 mile test hits. Amsoil 10 40. The oil looks black. the picture is right as I tilt the bucket to one side and let the oil flow to the side. You can see all this soot in the oil. Is it contamination from blow by as I did have a cylinder leaking down. I was just running e85 for the first time.
L79racer is offline   Reply With Quote
Old 05-14-2016, 05:23 PM   #2
Chevy55
Banned
Liked 179 Times in 89 Posts
Default Re: sooty oil?
Being no one answered my suggestion would be to get a sample and have it annualized.
When I use to deal with Black Bear in Farmingdale they'd run samples, no charge.
Also you could ask at Motorworks, Sunrise Highway, Amityville if they'd do it for you.
That's all I have!
Chevy55 is offline   Reply With Quote
Old 05-15-2016, 05:04 AM   #3
L79racer
L79racer's Avatar
That's all I have!
Thanks, for responding. I showed a friend and he said it was definitely contamination from bad ring seal. Motor is coming apart. I had a few cylinders with some bad gouges at the top of walls.
Old 05-15-2016, 10:06 AM   #4
Todd Gross
Liked 54 Times in 24 Posts
Did you run a break in oil prior to putting the Amzoil in? Some of them, such as Driven BR will leave traces of dark oil suspension.
Todd Gross is offline   Reply With Quote
Old 05-15-2016, 04:06 PM   #5
L79racer
L79racer's Avatar
Ive been running amsoil in the motor. It was a fresh oil change not a new motor.
Old 05-16-2016, 05:24 AM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by L79racer View Post
Ive been running amsoil in the motor. It was a fresh oil change not a new motor. I showed a friend and he said it was definitely contamination from bad ring seal. Motor is coming apart. I had a few cylinders with some bad gouges at the top of walls.
why would you tear an engine down that is otherwise running fine, because of "sooty oil" and the opinion of one as to why?
Do a leak down first.
Old 05-16-2016, 07:48 AM   #7
carl hinkson
Liked 18 Times in 10 Posts
Yes a leak down at TDC and about 40* before TDC is a good place to start.
There are a lot of shops out there that do not believe in plate honing!!!!
carl hinkson is offline   Reply With Quote
Old 05-16-2016, 07:58 PM   #8
L79racer
L79racer's Avatar
If you read into my first post I said I had a cylinder leaking down. I did the test and found I had a problem. Pulled the head and had gouges in the cylinders causing the leak down. So when I drained the oil I found the sooty stuff in it. I just wanted to confirm it was combustion contamination in the oil. So I torn the motor down and will be pulling it shortly. I am in the process of building a new LS motor so timing was kind of ok in a messed up way.
