Old 05-11-2016, 07:52 AM   #1
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Unhappy Aerospace AC-205 front disc brakes
Having trouble getting the pistons to "retract" back into the calipers for installing new pads. Any tips?
I do crack the bleeders as I push the piston in, but they don't want to move. I only need about .320 between the pads for the rotor but no go.... TIA
Old 05-11-2016, 08:00 AM   #2
Bobby DiDomenico
Liked 104 Times in 53 Posts
Default Re: Aerospace AC-205 front disc brakes
Never worked on them but might the piston turn to retract?
Old 05-11-2016, 08:13 AM   #3
rallye bob
rallye bob's Avatar
They don't look to be that type of piston, Bobby.
Old 05-11-2016, 08:15 AM   #4
Dragsinger
Liked 99 Times in 60 Posts
Bob,
the pistons should easily move back in the bore. Opening the bleed screw is not necessary [although it is OK to do so] Simply removing the master cylinder lid/caps will allow the fluid to displace back into the master cylinder.
Suggestions;
a local parts store will have an assortment of tools designed to "push" the pistons, might even be able to borrow or rent the tool.
another common method, use a wide C clamp. With an old brake pad covering the pistons straddle the C clamp over the old pad and caliper housing.
Using a tool or C clamp, if the pistons does not easily retract you have a problem. Could be corrosion build up in the bore.
Larry Woodfin 471W
Old 05-11-2016, 09:51 AM   #5
Nick_Siebert
Liked 80 Times in 13 Posts
I had the exact same problem with Aerospace front brakes on my previous stock eliminator car, even sent them back to Aerospace to have them rebuilt, they claimed there were no problems but when I got them back they were fixed. Just 3 races after getting them back, the pistons again failed to retract. After listening to Aerospace continue to tell me what I was doing wrong, I purchased a set of Strange Brakes and the problem was immediately fixed to never rear its head again.
Aerospace brakes look pretty, but that's about it. Do yourself a favor and call Strange, Mark Williams, Wilwood or Lamb.
Nick_Siebert is offline   Reply With Quote
Old 05-11-2016, 07:47 PM   #6
Rsmith38
Liked 28 Times in 15 Posts
When I built my Comanche aerospace was the only one available. they had me send in the spindles and made mounting plates to fit at a very reasonable cost (IIRC $45 more than the standard front package) been using them since 2004 - still work fine!.
Rsmith38 is offline   Reply With Quote
