Old 05-09-2016, 11:42 AM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default M&T Wrinkle Wall vs M&T Bracket Radial
First thing noticed was the Radial was a heavier tire.
Should not leak like the Wrinkle Wall.
Typically run 25lbs in the WW.
Guessing the same tire pressure in the Radial.
What will the car experience between these tires?
1995 Impala SS typically 4200lbs with me in it.
Dan
Old 10-17-2016, 06:59 PM   #2
423dak
Liked 7 Times in 1 Post
Default Re: M&T Wrinkle Wall vs M&T Bracket Radial
I went to the pro bracket radials. 23 to 24 psi is fine. Small burn out is a must. Little to no smoke. 60s are much more consistent. I have heard of guys seeing big 60 gains. I found they were just more consistent.
423dak is offline   Reply With Quote
Old 10-18-2016, 05:07 PM   #3
cad
cad's Avatar
Liked 93 Times in 52 Posts
Dan - which slick are you running now (at 25psi)?
