Old 05-02-2016, 11:15 PM   #1
older racer
Liked 68 Times in 26 Posts
Default Msd
hi, I see how MSD wires their relay 8961 into two step and clutch switch.
how does it switch from high side to low side?? the instructions in book doesn't tell you anything . I tried calling all three numbers, and no answer. do you have to install a switch , to select high side and low side ? just curious, as going to install the relay in a clutch car. like to know before hand. thanks
older racer is offline   Reply With Quote
