Old 04-14-2016, 08:35 AM   #1
HR 9505
Default Stock Powerglide case cracking in the reverse curcuit
I'm currently on my second stock powerglide case that has split or cracked in the reverse circuit and leaks bad when the transbrake is applied. I have run stock cases for years with no issues but I had one to crack last year and now this one. I know these cases are 40 years old and it's basically a crap shoot whether you got a good one or not. I was wondering if there is a main reason why these things crack in this area or could I have an alignment issue. I'm running a 3500# 55 wagon with a SBC 406 on alky running 6.30's and 40's wide open. Could I be at that fine line of power vs weight that could be causing this? Before I found another stock case, I wanted to see if going to an aftermarket case would be better fit?
Thanks in advance!
Jason
HR 9505 is offline   Reply With Quote
Old 04-14-2016, 05:22 PM   #2
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
Default Re: Stock Powerglide case cracking in the reverse curcuit
Jason
How is your engine and transmission mounted to the frame?
STK1217 is offline   Reply With Quote
Old 04-14-2016, 08:18 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
X2 on mounting.
Case cracking in this area is usually due to flex in mounting , lack of a mid plate ,and engine limiters. .....Just gets worse when you apply more power.
I just had a customer with a stock mounted LS engine with a glide experience the same problem . got away with it until he boosted the power.
If you already have a mid plate and limiters, do not use a solid trans mount , as there can still be enough flex to crack a stock case. Driveshaft alignment should also be checked .
Bottom line , stock cases are at least 40 years old , many may have been in wrecks and subject to unknown stress before being used for racing. ...They have served valiantly ,but are very weak compared to the aftermarket cases .
Old 04-14-2016, 10:11 PM   #4
SGSST109E
Liked 126 Times in 61 Posts
Make sure your drive shaft isn't bent. A common cause of cracking in the rear of a pg case.
SGSST109E is offline   Reply With Quote
Old 04-15-2016, 08:23 AM   #5
HR 9505
In response to the mounting here is what I have. I have solid motor mounts up front (no front plate but they are solid mounts bolted to the front of the motor), no limiters and I'm running a stock style rubber transmission mount on the rear.
I will check drive shaft alignment and also have the shaft checked for straightness.
Thanks!
Old 04-15-2016, 08:28 AM   #6
HR 9505
Also....as far as driveshaft alignment goes, is there a maximum number of degrees down between the tail housing and the driveshaft I should have? What would be considered "misaligned" I guess is what I'm asking?
Thanks!
Old 04-15-2016, 11:05 AM   #7
Tom Goldman
If your car sets high in the rear , it may be advisable to lower the rear crossmember or raise the front of the engine.
I would never want to see more than about 4* on the front, especially if the car is a leaf rear suspension.
