Old 03-31-2016, 08:31 AM   #1
dragrazer
Liked 2 Times in 2 Posts
Default Transmission Rockin
When the car is in park and running. Once I goose the throttle the car rocks forward. Any suggestions
dragrazer is offline   Reply With Quote
Old 03-31-2016, 12:59 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Default Re: Transmission Rockin
Common on Powerglides with 7 or more direct clutches .
Check with your trans builder on how many discs you have and how much clearance they have.
Even with increased clearance there will still be some rocking due to the drag of so many clutches ,especially when the fluid is cold.
That's why Stock and SS cars run as few clutches as possible and run o ring segments between the plates to keep the discs from creating drag and slowing up ET, not a big issue on most .90 cars.
Old 03-31-2016, 11:32 PM   #3
dragrazer
Thanks, that is exactly what I have. I'll contact my transmission builder Kenny (PTC).
Old 04-01-2016, 12:29 PM   #4
Bill Baer
"When the car is in park and running. Once I goose the throttle the car rocks forward. Any suggestions"
Unless the parking paw has been removed it's impossible for the trans to rock significantly (it's mechanically locked) if it rocks in neutral as stated previously is a result of the direct (high gear) clutches dragging and is pretty much normal and to be expected. Don't worry about it.
Old 04-01-2016, 04:23 PM   #5
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Also double-check that your shifter cable is adjusted properly. Check it in more than one gear position. I like to check Park and Low.
S/ST 51
S/C 53
