Old 02-23-2016, 03:18 PM   #1
PETE PEERY
Liked 33 Times in 11 Posts
Default Need info engine guys
sbc super stock, going from 50mm roller to 55mm babbitt cam brgs. Purchased durabond GMP-55T coated brgs but they have 3 oil holes. Just makes me think more excessive oil leak. Anyone make them with 1 or 2 holes? Any thoughts or insight would be appreciated. Thanks, Pete
PETE PEERY is offline   Reply With Quote
Old 02-23-2016, 05:32 PM   #2
SSDiv6
Default Re: Need info engine guys
Pete, you are correct; the 3 hole bearing will cause an oil hemorrhage.
Chris Straub of Straub Technologies has the appropriate 55mm bearings with a single hole.
www.straubtechnologies.com
Old 02-24-2016, 10:44 AM   #3
PETE PEERY
Thanks for the info. Parts on the way.
Pete
Old 02-24-2016, 02:52 PM   #4
carl hinkson
Liked 18 Times in 10 Posts
Pete
I had those cam bearings built and Chris is a vendor for those cam bearings. What block are you going to use them in ?
carl hinkson is offline   Reply With Quote
Old 02-29-2016, 12:49 PM   #5
PETE PEERY
using casting # 184 bowtie with 2.282 tunnel bore. I do not know why companies put 3 holes in them .
Old 02-29-2016, 11:18 PM   #6
carl hinkson
Richards Maskins told me he had to come up with a cam bearing that was child proof and that fits the bill.
I had those cam bearings build with one hole and a groove and on the Dart blocks one hole lines up with the hole in the block and another hole can be drilled 3:30 to 4:00
If that a priority oiling block the 3 center cam bearing line up with oil hole in the journal.
On the front and rear you can clock them appox. 10:00 with the block up side down.
Good luck with those bearings and questions feel free to give me a call 207-892-7215
