Old 02-15-2016, 07:54 PM   #1
Eman
Liked 133 Times in 76 Posts
Default Trans shield 3rd Gen f body??
I have a T350 behind a small block in my 3rd gen Camaro. What trans shield will fit? I've got a CSR, both the form fitting one and the one that goes at the rear section. There is no way the form fitting one will fit with a stock floor pan and firewall that I can see. Tell me if you can get one to work. The rear shield will go in but it's going to take some work around the shift cable and my header collectors. It sure is tight under there!
Old 02-15-2016, 08:43 PM   #2
HR9121
HR9121's Avatar
Default Re: Trans shield 3rd Gen f body??
I run a TH200 but no shield, all I can say is good luck!
James Williamson
W200 J/SA. SS/JA
Old 02-16-2016, 10:07 AM   #3
SSGN
SSGN's Avatar
Liked 202 Times in 52 Posts
I have some friends having the same issues and looks like a blanket is the way to go. Some nice blankets out there today in a couple different lengths.
The more people I meet the more I like my dog
Kevin
Old 02-16-2016, 03:35 PM   #4
Ken Haase
hey Kevin, what brand of blankets are you referring to? I have the same space issues, trying to use a TH400 in a '65 Chevelle. A really small tunnel since they used PG's only.
When using a blanket, what's everyone's opinion on clearance for the shift cable? Sorry if I steered us off course.
thanks, Ken
Ken Haase is offline   Reply With Quote
Old 02-17-2016, 03:15 AM   #5
SSGN
SSGN's Avatar
Lightbulb Re: Trans shield 3rd Gen f body??
thanks, Ken
Most are using the RCi but Stroud and Deist also make blankets. A nice trick is to use 2 of these clamps and mount them to the bolts that hold the tranny pan on, then put a piece of electrical tubeing threw the clamps. This supports the blanket and keeps it off the linkage.
http://www.homedepot.com/p/1-in-Rubb...7795/100160272
Kevin
Old 02-17-2016, 11:10 PM   #6
Eman
I tried the metal CSR shield and I can get it around the trans. The shift cable is where I'll have a problem and at the Rt. header collector. I'll need to order a shift cable bracket to modify and i think it will fit with some modifications.
I didn't want to wrap the trans in the blanket, but I do have one to try. I figured the shift cable would be a problem with the blanket also.
