Old 02-06-2016, 05:08 PM   #1
Kegracing
Default which main and rod bearing to check first?
OK, on a "good" running small block Chevy engine, no visible or audible issues...
If I want to take a quick look at a main bearing and rod bearing, looking for general condition of bearings, which would you pull?
Know it is best to look at everything, and know that any one could be an odd draw, if machine issues were off, etc. Just looking for opinions.
thanks
Ken
Kegracing is offline   Reply With Quote
Old 02-06-2016, 05:54 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: which main and rod bearing to check first?
More times than not when a SB spins a bearing and breaks a rod for some reason it was usually on #5 and 6 rod journal....
I have no good reason why that is true but saw it many times...
Rich Biebel
S/C 1479
Stock 147R
Old 02-06-2016, 08:52 PM   #3
jims5600
Liked 21 Times in 9 Posts
I agree with Rich, been my experience too. If you use a trans brake,with a loose converter,the thrust bearing wears quickly.
jims5600 is offline   Reply With Quote
Old 02-06-2016, 10:11 PM   #4
Kegracing
Thanks Guys.
Much appreciated.
Ken
Old 02-06-2016, 10:26 PM   #5
pmrphil
Liked 348 Times in 152 Posts
Normally I'll look at #2 and #4 mains, as any crank flex usually shows up there first.
Phil Molski
PMR Performance
S/C 1623
Old 02-07-2016, 10:37 AM   #6
Dave Gantz
Liked 251 Times in 125 Posts
I have a 350 in a work truck with a knock. A friend who owns a repair shop told me to pull the ones farthest from the oil pump first.
I haven't been able to do it yet. I had shoulder surgery in the fall and can't work over head. Something tells me a new short block is in my future...
Old 02-07-2016, 12:32 PM   #7
V M Kauffman
2 and 4 on mains due to crank bending on rods I was taught to do the first pair of rods that get oil from pump. Reason if pump sucks air (runs out of oil) it will show up there rod journal 1 & 5 on a small block Ford.
V M Kauffman is offline   Reply With Quote
Old 02-07-2016, 01:37 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Always #2 & #4 on the mains ,even if the rods look good ,which they sometimes do, those two mains are the precursors to doom !
Old 02-07-2016, 06:03 PM   #9
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
If the pan is off. Why not check all of them for the time it takes? That way you won't be wondering. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 02-07-2016, 09:23 PM   #10
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
I used to buy 454 core Chev engines. If 5 & 6 rod bearings were good, the rest were good. If they were bad, you usually would find a burned main bearing.
