Old 02-04-2016, 03:05 PM   #1
FrankM
FrankM's Avatar
Liked 3 Times in 2 Posts
Default Gear Ratio?
I am going to be ordering a 12 bolt from Moser for my 95 Firebird Pure Stocker. Using the online calculators like Wallace Racing seems to indicate with a 28" tire the right gear would be a 4.56. Assuming the car runs right it should be in the 110-115mph range. Are my calculations right or do I need less or more? Keep in mind this is a Pure Stocker with restricted valve springs so can't handle high revs.
Thanks,
Frank
FrankM is offline   Reply With Quote
Old 02-04-2016, 03:55 PM   #2
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Default Re: Gear Ratio?
My bracket car had a 28" tire, went 116 MPH and was turning 6400 RPM if that helps.
Old 02-04-2016, 09:05 PM   #3
FrankM
FrankM's Avatar
That does help, thanks.
Old 02-07-2016, 01:23 PM   #4
Eman
Liked 133 Times in 76 Posts
I'm looking at changing gears in my 3rd gen bracket car. The Wallace calculator doesn't seem to allow for converter slip, assuming you have an automatic. I run 29" tall tire and a t350 with 4.50 gear and at 100mph in the 1/8th my car is at 5900-6,000RPM. Wallace calculator says 5213 for my gear/MPH.
Wallace uses MPHxGear Ratiox336 divided by Tire Height=RPM
Old 02-07-2016, 02:56 PM   #5
Rsmith38
Liked 28 Times in 15 Posts
Slippage on my low HP stocker (8" converter) is about 6%.
Rsmith38 is offline   Reply With Quote
