Old 01-27-2016, 08:34 AM   #1
SS Racer 4901
Default Tire choice for stick shift stocker
Building a local stick shift car along the lines of a stick shift stocker with 9" tire. Car weighs about 3200#, will run mid 10s. Need a tire recommendation.
SS Racer 4901 is offline   Reply With Quote
Old 01-27-2016, 09:05 AM   #2
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Default Re: Tire choice for stick shift stocker
I had good luck with a HOOSIER 18200D07. Went mid 9's with a 3500lb stick shift stocker. If you decide that's the way you want to go. message me and I could get some drop shipped to you.
Chuck
C and W Racing is offline   Reply With Quote
Old 01-27-2016, 11:09 AM   #3
Charley Downing
Liked 620 Times in 87 Posts
Sounds like your combo runs about the same weight and ET as mine.
I have ran the 29.5 x 9 M/T stick Stocker tire for the past 5 years. That's the best stick tire I have found hands down.
Only two Stock/SS guys with stick shift finished in the top ten both run M/T, need I say more. Call M/T and ask for Buddy he's real easy to deal with.
As far as tire life goes I get around 1 season out of a set
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 01-27-2016, 05:04 PM   #4
Bill Belden
Bill Belden's Avatar
M/T 3056st on a 10 in rim best way to go
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 01-27-2016, 06:28 PM   #5
Hagen Gary
Liked 34 Times in 10 Posts
My pops has a set of M/T that would work great. 5 passes on them. cheap. Lafayette, La.
call Harvey 337-258-5564
Hagen Gary is offline   Reply With Quote
Old 01-27-2016, 09:23 PM   #6
600ci
Liked 3 Times in 1 Post
stiff side walls & use tubes
600ci is offline   Reply With Quote
Old 01-28-2016, 08:17 AM   #7
SS Racer 4901
Thanks for the replies... Very helpful.
Anyone have any trans ratio recommendations? Going to run a liberty and didn't want to get stuck with a bunch a ratios.
Thanks again!
Old 01-28-2016, 10:17 AM   #8
Run to Rund
Liked 54 Times in 27 Posts
The 30x9 D07 Hoosier works well for me, bought per Curtis Coulter's recommendation, former D/S record holder.
First gear should be at least 3.08, and some use 3.19 or 3.29.
Old 01-28-2016, 11:08 AM   #9
Aaron Allison
Liked 146 Times in 42 Posts
I have also used the Hoosier 18200 (30/9-15) with the “D07” compound and they are amazing. I can honestly say that the car with a Jerico and the Hoosier Stick tire is much more consistent than it ever was with an automatic and radials. I won two National Events and one Divisional on my last set. (NHRA and IHRA)
Aaron Allison 395 STK, 395 SS, 3395 SC
Aaron Allison is offline   Reply With Quote
Old 01-29-2016, 08:44 AM   #10
SS Racer 4901
Very helpful. Thanks. See other post for gear ratio & clutch recommendations.
