Old 07-09-2007, 05:31 PM   #1
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Default Solid Body Mount Bushings
Installing CE solid bushings in my 78 Camaro. They say to invert the upper bushing that you replaced and use it as the lower. There is a steel sleeve that prevents the rubber part of the bushing from contacting the frame which prevents the frame from tightning up on the body. Trim the steel sleeve, or use a shorter bolt with a washer and bolt it up solid?
Joe Marcinowski
3377 I/SA
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 07-10-2007, 07:29 AM   #2
Mike Savelle
Liked 7 Times in 5 Posts
Wink Re: Solid Body Mount Bushings
shorter bolts and a nice thick washer works well . Mike
Mike Savelle is offline   Reply With Quote
Old 07-11-2007, 06:10 PM   #3
Joe Marcinowski
Default Re: Solid Body Mount Bushings
Mike,
Thank you for the response.
Later,
Joe
