Old 01-20-2016, 08:48 AM   #1
Maxie fury 64
Default Race pak O2 sensor
Race pak says 12" from header flange. Which cylinder is best one to put it in? 440 six pack challenger.
Maxie fury 64 is offline   Reply With Quote
Old 01-20-2016, 03:00 PM   #2
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Default Re: Race pak O2 sensor
We usually aim for the area near the first bend. As for which cylinder if you are only running one might just put the a bung in each collector and shoot for the average. If you are still putting in all 8 and just switching it from cylinder to cylinder then start at the corners. Really depends on your intake design and distribution if you talk to the carb and intake guys they will want all 8
sst7250 is offline   Reply With Quote
Old 01-21-2016, 01:21 PM   #3
MOTORSPORTS Innovations
MOTORSPORTS Innovations's Avatar
Liked 15 Times in 2 Posts
If the headers are out I'd recommend putting bungs in all 8 tubes - only costs $50. http://www.motorsportsinnovations.co...band-bungs.htm
www.motorsportsinnovations.com
MOTORSPORTS Innovations is offline   Reply With Quote
