Old 12-23-2015, 01:10 PM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default 10 Bolt Dropout 4.11 Gear
I have a friend looking for a 4.11 street gear for a 10 bolt dropout. Does anyone have anything like this or a known vendor. It looks to have an odd 17 spline pinion.
Thanks for any help!
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-23-2015, 01:59 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 10 Bolt Dropout 4.11 Gear
Sean,
are you speaking of a Chevy 3rd member? If so, that unit fits 1955 - 1964 Chevy cars. Parts are out there for those.
Larry Woodfin 471W
Old 12-23-2015, 02:37 PM   #3
Sean Marconette
Hi Larry!
Yes that's what he has,
It looks like the 4.11 gear is an odd one to find. I found an entire posi and gear kit, but not just the gear set by itself? He has everything but his gears are junk.He has called vendors and has not had much luck.
Thanks
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-23-2015, 05:01 PM   #4
FED 387
Liked 335 Times in 182 Posts
SEan-- check your PM- FED 387
Old 12-23-2015, 06:39 PM   #5
Sean Marconette
Thanks for the help. It's always a pleasure to know help is available here!
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-24-2015, 10:45 AM   #6
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
4.11's , 4.56's are readily available new. In fact, I believe that Richmond is making the 3 series gear sets as well.
There are also modern re-enforcement upgrades for these rear ends.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 01-11-2016, 12:17 AM   #7
56sedandelivery
4.11 factory ring gears are pretty narrow (weak), but that's what the 3-speed overdrive transmission cars came with. Gears are still available new from the aftermarket, but this is an area where E-Bay is your friend. I have a bunch of the 55-64 dropout third member stuff; just gave away an open 3.70 unit and a set of new Schiefer 5.57 gears. Go to BruneauPerformance.Ca (a Canadian site), he has stuff also for these rears. Butch/56sedandelivery.
56sedandelivery is offline   Reply With Quote
Old 01-11-2016, 12:35 AM   #8
Sean Marconette
Thanks for everyone's PM's and responses!
I think my friend has this taken care of now. We found someone with several new gear sets on ebay. The car is just a driver, and I guess it had this setup when he started the build.
Thanks
Sean
Sean Marconette
84 Mustang
5060 SS/N
