Liked 212 Times in 64 Posts
I'm going to be replacing the front springs and shocks on my 1967 Camaro. Big block automatic mid ten second car. I currently use Moroso Trick springs and Comp Engineering three way adjustable shocks. I see that Afco sells a front shock with coil over springs. My question is this: Should I use this Afco style front suspension with the coil over springs, or stick with the Moroso springs and just use the Afco shocks up front? Or is there a better combination out there?
Liked 1,916 Times in 574 Posts
Santhuff is the best for the gen 1 cars. They have springs, shocks and the coil over set up that you mentioned. I have their double adjustable shocks and ,moroso springs on my car. I don't know anyone that has run the coil over set up. I would like to hear if anyone has .
Mike Pearson 2485 SS |
