Old 12-13-2015, 03:56 PM   #1
Kegracing
Default how to ID this converter?
Bought a glide yesterday, and converter came with it. Guy I got it from had gotten it with a car he bought, never ran it. Did not have any info on it. Glide with a brake, came out of a BBC Camaro.
Stamped on the trans side face is: 073 HF LS
I dont see anything else stamped on it. Looks like an 8" converter, turbo spline, with 1/4" thick ring welded around the bolt ears.
Any idea who made this and/or any spec's on it?
Thanks in advance.
Ken
Kegracing is offline   Reply With Quote
Old 12-16-2015, 05:15 PM   #2
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
Default Re: how to ID this converter?
Hi, the only info I could give you on those stampings is that it has an Opel 073 style stator in it, the HF would designate high flow, the LS would designate low stall. Without opening it you cannot tell the pump blade angle or clearances. I would guess it would have a positive pump angle with a low stall stator, so it would probably be a low stall piece for an 8". Hope this helps a little.
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
Old 12-22-2015, 05:00 PM   #3
Kegracing
Thanks Lenny!
Will shelf it for now, might try it with a bracket combo some time. I pulled pan on trans, fluid clean and inside of pan pretty clean. Little gray gunk, but no metal and not many flakes.
Maybe all is good with it.
Merry Christmas all.
Ken
Old 12-23-2015, 11:24 AM   #4
Sponsor
Thumbs up Re: how to ID this converter?
Merry Christmas to you and yours sir
Lenny Croteau
Phone 704-892-6837
Old 12-26-2015, 01:43 PM   #5
John H186
How about an ATI unit?
It has A421 1603 on snout.
Looked all over. Can't seem to find an ATI code chart.
John Hedenburg H186
John H186 is offline   Reply With Quote
Old 12-26-2015, 02:01 PM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Call (410) 298-4343 Monday morning after 8:30 ask for Charlie.
