Old 12-06-2015, 10:50 AM   #1
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Default CD/Crane/Chet Herbert Camshaft Identification
I've got an old camshaft of which I'm trying to the specifications to. From what I've read, it seems to be a Crane Cam Core with a Chet Herbert grind but in searching there were two cams with two different specs that used the 689356 number so I'm trying to verify the cam information. Please, can someone help me in finding the original cam specs. Also, this cam is specifically for a Big Block Mopar Wedge engine(3 bolt).
The number on the rear of the camshaft is: 689356(I believe this is the part number) 8A2A(I believe this is the heat treat batch number)
The number on the front of the camshaft is: CD274-06 then 274 is listed again by itself. Also No. 4586 is on the front of the cam as well.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 12-06-2015, 12:19 PM   #2
ghost
Liked 16 Times in 11 Posts
Default Re: CD/Crane/Chet Herbert Camshaft Identification
I try to help you
I have old catalog from Doug Hebert. (Is the same to Chet)
CDR274...
DUR INT 310 EX 322
at .050 int 275 ex 286
lift with 1.5 .int 652 ex .643
lobe lift int .435 ex .429
lobe C 109c
lash .030 .030
I hope to help you
ghost is offline   Reply With Quote
