Old 11-09-2015, 07:59 PM   #1
danoone
danoone's Avatar
Default 1967 Camaro SS frame
I am going to be restoring an old Super Stock car. The rear clip has been replaced along with a new cage installed. So I am planning on rebuilding the car as a legal Super Stock. What modifications can be done to the fame and what are normally done. All mods, bushings control arms, relocations, frame mods that are legal. Thanks Dan
danoone is offline   Reply With Quote
Old 11-09-2015, 09:18 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,926 Times in 579 Posts
Default Re: 1967 Camaro SS frame
You can cut the center of the frame out for oil pan clearance. Double adjustable shocks are needed on the gen 1 Camaros. Bump steer kit. Stock A Arms must remain. Good springs. New bushings and ball joints. After market disc brakes.
Mike Pearson 2485 SS
Old 11-10-2015, 01:40 AM   #3
danoone
danoone's Avatar
I have been reading on here about not using poly. I saw someone makes spherical lower ball joints as well as the delalum bushings. I am a first gen Camaro guy. I did not buy this car 18 years ago but took the second chance. I am seeing some creative front end work that was done. Originally built and raced by Joe Scott. Which is the better engine combo, 327 or 350 to run? I have Moroso front springs. Was leaning toward Calvert, but want to hear what the guys who race know what works. Car has stock front floors and new S&W ladder bar frame. The trunk floor center is in. The rest of floor is gone. Can I use plain steel to replace what is missing. from the frame rails out to the trunk drop offs floor under rear seat area, and flooring over the rear end or does it have to be factory metal? So if you remember this car you are at least 55 years old.
Old 11-10-2015, 08:56 AM   #4
Mike Pearson
It should have the factory metal from the front of the ladder bar forward. The area behind that and out from the frame to the body can be flat metal. I have stock type Moog bushings and ball joints. Some of the guys put a longer ball joint on the top A arm to help with bump steer and geometry. I have not done that and my bump steer is less than 1/4 inch. I put a vega steering box and a light weight steering column with a removable wheel as well. I have Moroso springs and Santhuff double adjustable shocks on my car. Let me know if you want some pics of my front end. I have the engine out of the car at this time. Aerospace brakes too.
