Old 10-21-2015, 07:56 PM   #1
Pony Pilot
Default Throttle Stop RPM Check
I wanted to check that my throttle stop RPM was correct before qualifications last week. I put the car on jackstands, turned off power to the stop, increased the 2-step RPM above the TS RPM and hit the trans brake button and gas pedal. RPM was high, so I adjusted the manual RPM knob downward and tried again. That attempt gave me the correct RPM. However, when I ran the first qualifier, I found the RPM 200 too low when I reviewed the run on my Racepak graph. What did I do wrong? Is there a better, safe, way to ensure my RPM on the stop is correct short of taking multiple shots down the track? Thanks for any advice you guys can provide.
Pony Pilot is offline   Reply With Quote
