Old 08-17-2015, 08:56 AM   #1
dwg4859
Default Back space
Im sure this has been asked before but what sixe wheel should i buy for a 69 nova stocker to run a 30 by 9.
dwg4859 is offline   Reply With Quote
Old 08-17-2015, 11:29 AM   #2
bigfoot584
Default Re: Back space
damn auto correct size
bigfoot584 is offline   Reply With Quote
Old 08-17-2015, 01:23 PM   #3
T Ketels
If I remember correctly, I ran a 15 x 8 with 5.5" backspace to clear a 30 x 9. I also ran a very minimal spacer (1/8") on one side to center it in the space available.
Tim
SS/MA
5017
T Ketels is offline   Reply With Quote
Old 08-17-2015, 01:28 PM   #4
dwg4859
great, thank you and I will from now on.
Old 08-20-2015, 08:20 AM   #5
Alan Nyhus
Liked 799 Times in 236 Posts
On mine, a 9" wheel with centered backspacing (4.5") fits perfectly.
"That'll never work....."
Old 08-20-2015, 08:45 AM   #6
dwg4859
Do all wheel manufactures make a 9 inch wheel?
Old 08-20-2015, 09:43 AM   #7
Alan Nyhus
8's and 10's are the most common sizes. Companies like Bogart, etc. will make any width you'd like. Weld makes their Pro Star in a 9" width with a centered b.s. that would make a nice wheel without going the 'custom' route.
http://www.jegs.com/i/Weld-Racing/92...oductId=746350
Old 08-20-2015, 10:20 AM   #8
dwg4859
That is awesome thank you
Old 08-21-2015, 02:16 AM   #9
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Champion wheel will make you what you want with backspacing in 1/4" increments. Light, look great and reasonably priced. http://www.championbillet.com/
Rich Taylor
I/SA - 321
Old 08-21-2015, 10:31 AM   #10
Run to Rund
Liked 54 Times in 27 Posts
Backspacing is generally done from the edge of the wheel to the mounting surface, so it includes the thickness of the rim from the tire to the edge, usually about 1/2 inch. So, zero offset on a 9" wheel would mean a backspace of 5".
