Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 08-14-2015, 08:46 PM   #1
Kegracing
Default New concrete shop floor coating recommendations
Building a new shop for the race cars, fab work, atv's, kids junk, truck and trailer, etc.
Would like some recommendations on what to do to the floor. Dallas, TX, so very hot and not too cold. Will not be heated or AC. Do not want epoxy.
I am thinking about a densifier sealer combo. Not looking for gloss. Just want to protect the concrete and make it easier to clean up.
Suggestions on what and what company to use?
thanks,
Ken
Stock 412
Kegracing is offline   Reply With Quote
Old 08-17-2015, 12:54 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: New concrete shop floor coating recommendations
Maybe? http://www.rhinolinings.com/news/pre...or-coating-kit
Rich Taylor
I/SA - 321
Old 08-20-2015, 01:26 PM   #3
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
Just putting the finishing touches on a 40 x 60 shop........
After my doors arrive I will also be looking for a floor covering......
I got some input from my concrete contractor on sealers and I am also in information gathering mode.....
It will be a sealer type for sure, but I don't know what kind or brand yet??????
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 03-22-2016, 09:45 AM   #4
Eric Voigt
Liked 18 Times in 11 Posts
I am finishing up 30 x 60 shop and did some research on the coatings and went with U Coat it system. I know the OP didn't want epoxy however this is the direction I went. I talked with Armor Coat and their system was really pricey and they had poor follow through.
The key is in the preparation and keeping moisture from weeping up. When we poured the concrete, prior we put down moisture barrier between the ground and the base.
With a "fresh pour" you have a far better shot with success of adhesion. Make sure to wash the concrete with acid twice to get concrete to open up and get a tight bound.
Most "non-epoxy" finishes with not hold up to tires sitting on the finish for long periods as the tires will breakdown the finish and pull up the coating.
Just passing on what I learned.
Eric Voigt 7425 STK
Eric Voigt is offline   Reply With Quote
Old 03-26-2016, 11:01 PM   #5
dfuelman
For what this is worth, my U-Coat-it floor is two years old and tires will still leave brown stains that do not come up. Not just the tires on my drag car, daughters Sea Doo, and my DD's will leave tire marks as well.
I do like my floor but I am disappointed in some of the durability issues that have come up. Scratches VERY easy, and for some reason the wheels on my shop chairs mark the floor and it's a dog to clean up.
Just my 2 cents.
dfuelman is offline   Reply With Quote
Old 03-27-2016, 07:39 AM   #6
SGSST109E
Liked 126 Times in 61 Posts
Sherman Williams has some good products. A concrete stain. Its a available in tints or just clear. It is solvent based. I rolled it on, it gets tacky very quickly. Gas, oil etc. doesn't effect it even after days. Tires won't pull it up. Makes cleaning up so much nicer. MY garage is 30' x 30'. New concrete floor just swept it clean before. MAchine floated floor that was very smooth.
SGSST109E is offline   Reply With Quote
Old 07-27-2019, 12:05 PM   #7
House of Darts
Liked 20 Times in 15 Posts
For your shop use the silver foiled bubble wrap insulation over the stone and before the rebar goes in. Keeps the floor cool/warm and is an excellent vapor barrier. Don't forget to add a thicker pad area if you will be adding a lift in the future. As for a surface finish, this is a pore sealer, 50/50 mineral spirits and polyurethane 1 months after the concrete cures(rinse and maybe some vinegar.. Unlike modern sealer that are acrylic and don't penetrate much.They are a top coating that wears and not solvent(brake cleaner) friendly. Being deep in the pores, the poly doesn't let oil seep in. You never have to re do it.
House of Darts is offline   Reply With Quote
