Old 08-11-2015, 03:16 PM   #1
a pontiac
Liked 36 Times in 11 Posts
Default voltage step down
Going to a 16 volt batteries and want to know if I should use a voltage step down device. There is resistor made by Bussman, cb22902-68, listed as a step down device. I know very little about this stuff and would welcome any help. I think I need this for the water pump, fan, and maybe the lights. Thanks
a pontiac is offline   Reply With Quote
Old 08-11-2015, 04:06 PM   #2
Roberte
Liked 14 Times in 8 Posts
Default Re: voltage step down
If I'm not mistaken, NAPA Echlin and Cole Hersee both
offer voltage reducers. Bob
Roberte is offline   Reply With Quote
Old 08-11-2015, 06:02 PM   #3
Jim Caughlin
Liked 805 Times in 245 Posts
I switched over to 16 volt batteries a few years ago and didn't change anything, no problems whatsoever running everything off of full 16 volt. Maybe other have had problems but not in my case. Overall, I think switching to 16V is a good idea and worth the money.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 08-11-2015, 07:23 PM   #4
Dragsinger
Liked 99 Times in 60 Posts
my experience with 16 volts is the same as posted above. Everything operated just fine, no need for any reduction.
Larry Woodfin 471W
Old 08-11-2015, 08:19 PM   #5
Ed Wright
Ed Wright's Avatar
My fans run faster, power windows are faster, starter spins faster, checked with my water pump, starter and fuel pump mfgrs, all told me they were made to be fine with 16 volts. Might loose a tail light bulb per season.
Ed Wright 4156 SS/JA
Old 08-11-2015, 09:08 PM   #6
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Wink Re: voltage step down
Ed, are your reactions times faster too?
Former NHRA #1945
Former IHRA #1945
T/SA
Old 08-11-2015, 09:23 PM   #7
Shake & Bake
Liked 37 Times in 33 Posts
I run a "single" 16/volt battery. I have a digital dash, O2 sensors, data logger, extra fan etc... I do not run an alternator. No problems what-so-ever.
If your going to make the switch, invest in a good 16/volt charger.
Shake & Bake is offline   Reply With Quote
Old 08-11-2015, 10:28 PM   #8
Ed Wright
Ed Wright's Avatar
No, I'm still 71 years old. LOL
Old 08-12-2015, 06:46 AM   #9
MrWendy'sJr
Liked 25 Times in 1 Post
One thing I have noticed is bulbs (head and tail lights) burn out faster. We keep plenty of spares in the trailer. Other then that never given us problems. And the starter works way better with the extra juice.
Jeremy Stock SS/KA 3574
MrWendy'sJr is offline   Reply With Quote
