Old 08-02-2015, 09:49 PM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Wink Soup up trick.
1/2 cup nitro in the pan is worth about .04or 03. One cup blows the rods out the side. You know when you passed the line is when you can reach in at the end of the track and pull out a piston. Just a thought before Indy.
Jeff Teuton 4022 STK
Old 08-03-2015, 07:43 AM   #2
Liked 10,909 Times in 2,256 Posts
Default Re: Soup up trick.
.03 to .04 pick up is only if you use the cheep stuff nitro, it has yellow die in it. The clear nitro (faster) is the way to go, its Indy, spend the extra $$$$. It's a bracket racer dream: " Go fast or go home".
Old 08-03-2015, 07:52 AM   #3
Billy Nees
Liked 7,864 Times in 1,750 Posts
Jeff, keep trying! You haven't got it jetted right yet!
Billy Nees 1188 STK, SS
Old 08-03-2015, 11:13 AM   #4
Ed Wright
Ed Wright's Avatar
Nitromethane in your oil??
Ed Wright 4156 SS/JA
Old 08-03-2015, 12:02 PM   #5
Liked 5,147 Times in 1,964 Posts
Try hooking up the PCV !
Old 08-03-2015, 12:17 PM   #6
Ed Wright
Ed Wright's Avatar
I do.
Old 08-03-2015, 12:27 PM   #7
I do.
I'm sure . I was trying to help Jeff to keep the rods inside the motor.
Of course you'd have to look long and hard for the ports on those "factory" combos.
Old 08-03-2015, 02:29 PM   #8
Signman
Liked 269 Times in 99 Posts
Why buy nitro just get used oil from the the pro teams!
Old 08-03-2015, 02:42 PM   #9
James Perrone
Liked 1,861 Times in 434 Posts
fact. Not fiction. ☺️
james perrone 1290 STK
Old 08-03-2015, 05:22 PM   #10
rod butcher
Liked 132 Times in 27 Posts
James is right. I was told several years ago, at Indy, that Buster shut off two SS/AA hemi cars on the starting line for a nitro smell in the early 1980's.
rod butcher is offline   Reply With Quote
