Liked 288 Times in 109 Posts
For the up-coming D 4 Lucas race in Shreveport I will change to a M/T Radial.
*On the truck now is M/T 3074S [14 x 32 stiff sidewall] mounted in 15" wide wheel I see two choices for me with M/T radial; * M/T #3073R is 13.5 x 31.9 with 100 rollout [I think this is the best choice] or *M/T #3074R which is 14 x 32.2 with 101.7 rollout Also, what about the 13.5" wide radial on a 15" wide wheel? Would a 14" wide wheel be better or not much difference? |
Liked 1,981 Times in 597 Posts
My car picked up 0.13 from bias to radial. You probably need the shorter tire. I run the 100 inch roll out Hoosier radial on my car with a 5.86 gear. 132 mph at 8600 rpm.
Mike Pearson 2485 SS |
