Old 07-31-2015, 07:52 PM   #1
Duster 318
Default Caltracs setup
I just put caltracs on my 1970 duster. I'm running the stock springs. I have them set at the baseline that they gave me. And it's unloading the tires any ideas on what to change?
Duster 318 is offline   Reply With Quote
Old 07-31-2015, 09:03 PM   #2
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Default Re: Caltracs setup
Split leaf springs and Cal trac.shocks will fix.thr.problem
Old 07-31-2015, 09:21 PM   #3
George Mirza
What torsion bars do you have? I had this problem with the V-8 bars, put 6cly bars in and that solved the problem.
I know of a few guys who couldn't get the cal tracs to work with the stock mopar springs. If you are going to run that setup you need all the recommended cal trac stuff, springs, shocks front and rear.
GEORGE MIRZA STK 1236
George Mirza is offline   Reply With Quote
Old 08-07-2015, 04:44 PM   #4
340Cuda
Liked 800 Times in 337 Posts
Ultimately you will probably want to go with at least their springs, however in the mean time give them a call, outstanding customer support. They can tell you what to try until you can buy the rest.
Good Luck,
Bill
