Old 07-27-2015, 07:52 PM   #1
Woodfin
Liked 288 Times in 109 Posts
Default continous duty solenoid as master switch
Racers,
I am considering a high amp rated continuous duty solenoid as my master switch. Anyone have experience with doing this?
In my situation it will be for weight saving reasons. I have the Super 10 on a weight reduction plan and removing the hardware that allows me to operate the cutoff switch while seated and from the rear will remove about 7 pounds.
Old 07-27-2015, 08:00 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,959 Times in 593 Posts
Default Re: continous duty solenoid as master switch
Originally Posted by Woodfin View Post
Racers,
I would just remove the system to operate from the drivers seat. It's a nice option but I have been racing for many decades and have never had a reason to use such a device. I would stay away from a solenoid as it uses power to hold in the connected position. You could look into a mechanically held contactor. They are more like a relay on steroids.
Mike Pearson 2485 SS
Old 07-27-2015, 08:26 PM   #3
bigfoot584
bigfoot584 is offline   Reply With Quote
Old 07-27-2015, 09:29 PM   #4
Ed Wright
Ed Wright's Avatar
I fully agree. KISS
Ed Wright 4156 SS/JA
Old 07-27-2015, 09:46 PM   #5
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I'm guessing you have a battery(s) mounted in the bed on the S-10? Using a continuous-duty solenoid to replace a Cole-Hersey style master cut-off switch would require you to run power to a toggle-switch of some kind inside the cab of the truck, somewhat defeating the purpose of the master-switch disconnecting all power at the battery. Better to have one mechanical disconnect at the rear for safety's sake.
Lew Silverman #2070
"The Wagon Master" N/SA
Old 07-27-2015, 09:58 PM   #6
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
I could see it working with this type of rear starter solonoid system.
Might take a little more creative wiring than what is in the pic to work as "all kill" switch tho.
Old 07-27-2015, 10:36 PM   #7
Woodfin
Almack, I do not run an alternator.
Old 07-27-2015, 11:44 PM   #8
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
How about a transbrake style solenoid rigged to the backside lever on the cut off where the Morse cable is? Power it off the battery with a normal off momentary switch in the cabin. Punching the switch would only preform one operation, but "Turn the darn thing on" is the main use of the cable lever.
Remember NHRA says one switch in the kill circuit only.
Dale
Dale Shearon
68 Mustang 6394
Old 07-28-2015, 03:05 AM   #9
Painter
Liked 162 Times in 45 Posts
I see two problems with this idea. First I dont believe a solonoid exists that will hold up in this application. But more importantly, in one of the two rule books it specifically says this is illegal. It may be in their big book that we dont get to see very often.
Painter is offline   Reply With Quote
Old 07-28-2015, 07:33 AM   #10
Kirk Morgan
Liked 81 Times in 45 Posts
We use a older Dodge diesel solenoid in our race car. It is the round type and we bought it at NAPA. I believe it was listed as a battery relay and was rated about a 100 amps. Hope this helps.
Kirk
Kirk Morgan is offline   Reply With Quote
