Just installed Del A Lum Bushings, and Landrum 180 lb front springs on a 69 Camaro. The front end weighs 1667 lbs.
Problem: car sits up with the front end fully extended...if i under stand spring rate correctly it takes 180 lbs to compress the spring 1 inch. If so each front wheel has 833 lbs of weight divided by 180 lbs of spring so it should come down 4.63 inches? Please Help Mark 210 392 9902 |
