Old 07-18-2015, 04:26 PM   #1
Bpozzi
Liked 120 Times in 21 Posts
Default Fuel Check Valve
Just putting the finishing touches on our super stock 68 camaro. Trying to determine how to get fuel out of the system for fuel check, were running a Holley regulator mounted to inner fender. Any suggestions or common practices? Thanks everyone!!
Bpozzi is offline   Reply With Quote
Old 07-18-2015, 05:04 PM   #2
John Nechiporchik
Liked 13 Times in 7 Posts
Default Re: Fuel Check Valve
I used an LSM unit that has a 1/8" NPT male fitting, a push button to release the valve, and a small fitting deposits the fuel. Works great.
When I researched it, the LSM was about half the cost of the JEGS unit of similar design. At the time (this past winter) That I got it, LSM had discontinued making them, but still had a few in stock. If they are not available, I'm sure the Jegs version will work fine. They are available with NPT or AN fittings.
E-mail me and I'll send pics of the install.
John
John Nechiporchik is offline   Reply With Quote
Old 07-18-2015, 05:38 PM   #3
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
I have an Aeromotive fuel check valve and it is installed into the fuel pressure regulator. I have a momentary button to turn the fuel pump on just for fuel check. Check Dragsingers build for good pictures of how Larry has his set up.
Sean
Sean Marconette
84 Mustang
5060 SS/N
