Old 07-16-2015, 04:23 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default trans temp sender location
Racers,
is anyone monitoring the cooler line outlet temp? [that is to say, the fluid temp as it exits the case] If so, tell me how you did the plumbing and did you learn anything useful?
Thank You
Larry Woodfin 471W
Old 07-16-2015, 04:37 PM   #2
SSDiv6
Default Re: trans temp sender location
Originally Posted by Dragsinger View Post
Racers,
Thank You
Larry, I don't see many racers monitoring the trans temperature and there are many that don't even use a trans cooler.
If you plan to do so, I recommend you use something similar to the Peterson Fluid Systems sender plumbing with a smaller size line.
http://www.petersonfluidsys.com/plumb_inline.html
Old 07-16-2015, 05:28 PM   #3
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
I have a trans temp gauge in my car but the sender is in the pan. And I use a cooler as well. 200 - 250 is common on my car.
Dave Noll, EF/S ,?/SA 6526
Old 07-16-2015, 08:39 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
You will be measuring the highest fluid temperature coming out of the transmission. Most production transmission run the outlet oil from the torque converter directly to the cooler.
Old 07-16-2015, 10:40 PM   #5
Kegracing
Larry,
I did this years ago on my 10.90/bracket car. Used a oversize brass 3 way fitting, bushed it down for the #6 braided hose I was using in and out. Dont remember the exact size, but was big enough that the probe in the center fitting did not hurt flow any...
I did this back before I was using synthetic fluid. Was setting up for .00x lights and trans temp/converter temp made a difference. Also impacted et's, but I used it more for my reaction time changes.
After I went to synthetic fluid, temps did not move as much, and did not seem to be as critical.
Just monitor pan temps now. But, also foot braking and not setting up for .oox's anymore either.
Look forward to seeing you soon.
Ken
Stock 412
Kegracing is offline   Reply With Quote
Old 07-17-2015, 03:55 AM   #6
Dragsinger
Ken, Thanks
We plan to test at Ennis July 25 and a date or two in August. Then the Lucas race in September at Thunder Road. be sure to look me up.
Larry Woodfin 471W
Old 07-17-2015, 02:07 PM   #7
njk53
The transmission fluid is at it's hottest at the stator. Unless you can place a thermocouple at the stator, the outlet side of the transmission cooling line going to the auxilary cooler or the radiator in-tank cooler is the best place. Place the probe as close to the transmission as best you can. Also, try to keep the probe away from an outside heat source such as the headers which could potentially give you a false reading.
Nelson Kowal
Stock 345
Old 07-17-2015, 02:27 PM   #8
colby
Ken, Thanks
Are you going to come to Noble in October?
colby is offline   Reply With Quote
Old 07-17-2015, 02:30 PM   #9
Dragsinger
Colby, most likely yes If you are there please be sure to look me up.
Larry Woodfin 471W
Old 07-18-2015, 08:24 PM   #10
ATI Performance Products
Sponsor
ATI Performance Products's Avatar
Liked 9 Times in 1 Post
Racers,
Thank You
We don't see any reason to monitor it there. Just in the pan. You want to see an overall situation of the temp. Not the hottest coming out of the converter. You are usually the hottest at some point after the run once all the hot fluid out of the converter has mixed in the pan.
To us cooler pressure is more important. It affects converter flash and coupling to a point. If you have two transmissions and one has 40 psi cooler pressure one has 80....the same converter will act different.
There is a ton of adapter fittings though with 1/8th NPT holes and -6 to -6 etc
http://www.summitracing.com/search/b...=npt%20fitting
ATI Racing
ATI Performance Products is offline   Reply With Quote
