Liked 132 Times in 30 Posts
I was told a midplate is just as important as a front engine plate on a "high" horsepower engine (above 800) due to movement in a car on a chassis dyno that didn't have one. I say it's a wives tale being they're not allowed in SS yet there are plenty of 900+ hp engines in SS/B - SS/AH with no problems.
Opinions?
Gary Smith "another broke racer spectating" |
Liked 171 Times in 36 Posts
Liked 240 Times in 112 Posts
Well, I'm a FFFFord guy an as such, Bob Glidden wouldn't use an engine stand. And thats on engine's not running.
Dave Noll, EF/S ,?/SA 6526 |
Liked 116 Times in 27 Posts
I run a Front plate and solid steel motor mounts in my SS/AS Mustang and it makes over 900HP, I have not seen any problems as of late.
Richard Preiser 1613 FGT/I 1510 C/SA 161 F/DA |
The use of a midplate is a plus and if the rules allows it, use it.
It stiffens the chassis and also limits the torsional twist and stresses on both the engine block and transmission. In many cars, it improves the 60' numbers, If you have to use a diaper, it makes the installation and removal easier. It makes engine removal easier too. |
#6 | |
Liked 99 Times in 60 Posts
SSDivn6 mirrors my feelings.
I think it is a good addition and see no down side to doing so.
Larry Woodfin 471W |
![]() On a similar topic.... "All motor plates, mid-plates, etc. must be separate from and may not be attached to the firewall." Can the mid-plate be bolted to tabs on the front of the chassis and firewall be welded to the outside? |
#9 | |
For Super Stock class, the firewall and mid-plate must be separate pieces. |
Does anyone have pictures of a legal firewall in FWD converted modified they wouldn't mind sharing?
