Old 07-05-2015, 09:32 PM   #1
race city
Default Class question
Curious as too where a 91 mustang 5.0 ho would fit in stock?
race city is offline   Reply With Quote
Old 07-05-2015, 09:45 PM   #2
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Default Re: Class question
Should be a L, M, or N class car depending on whether it is a coupe, hatch, or convertible.
Stick or Automatic ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 07-05-2015, 09:50 PM   #3
http://www.classracerinfo.com/CGPage...1&MAKE=Mustang
Old 07-05-2015, 09:52 PM   #4
race city
Was a stick, but I installed a c4....and I converted it from fuel injection too carb. I know that prob changes things a lot.
Old 07-05-2015, 10:03 PM   #5
race city
Thank's Mark that page was helpful.
Old 07-05-2015, 10:41 PM   #6
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Might be tough to pass that '91 off as a '85 body style for a carb.
Rich Taylor
I/SA - 321
Old 07-06-2015, 11:38 AM   #7
ALMACK
ALMACK's Avatar
Yep.
You will have to change the front nose, interior dash assy. (and door panels), the side quarter windows as well as the tail lights to make it appear as an '85.
Here are the numbers for an '85 Mustang
http://www.classracerinfo.com/CGPage...5&MAKE=Mustang
I/PS '95 Mustang GT
Old 07-06-2015, 12:10 PM   #8
Rory McNeil
A 4 barrel carbed 85 Mustang 5.0 is a stick only combo, in addition to all the body changes to convert a 91 to a 85, the 85 engine also uses different head castings, pistons, not to mention you need to use the correct Ford E4 intake manifold and an approved carb. The easiest way for this car to run in Stock would be to put the EFI back on, and run it as a 87 thru 93 Mustang, which is legal with either a stick or automatic, plus you would not need to find,paint and install the 85 body panels and interior. You may want to give this effort some serious consideration and do some research before turning a wrench.
NHRA 6390 STK
M/S 85 Mustang
Old 07-06-2015, 04:19 PM   #9
ALMACK
ALMACK's Avatar
I totally agree with Rory ^^^
Good advice.
I/PS '95 Mustang GT
Old 07-06-2015, 04:34 PM   #10
HandOverFist
By all means, join the efi tuning ranks...it's so easy.
Rich Taylor
I/SA - 321
