Old 06-30-2015, 10:16 AM   #1
Liked 11,032 Times in 2,267 Posts
Default Fuel System
After reading the rule book for the umpteenth time, I realized that I had my fuel pump wired wrong. The pump would not stop when the ignition switch was turned off. The wiring has been corrected.
Check your stuff and be safe.
Old 06-30-2015, 10:50 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Fuel System
I'm in the habit of using my master cutoff. I added a lever next to the shifter with a Morse cable back to the battery switch like Woodfin. I'll try the ignition switch on the panel today when I move it in for pain touch up just to make sure it works that way too. Thanks for the heads-up.
Dale
Dale Shearon
68 Mustang 6394
