Old 06-17-2015, 01:06 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default 3.5" aluminum driveshaft 54" in length, who runs one?
This topic is under discussion on my Super 10 build thread but I want more to see the question so posted here.
I am curious if some of you have an aluminum driveshaft, 3.5" OD, .125 wall, 54" in length, in race service.
The Super 10 will have a 32 x 14 bias tire, 6.0 gear, and for purposes of math use 5% converter slip. Since it has never run the finish line RPM is unknown.
The expect ET is 10.40 - 10.30 range.
One poster explains that finish RPM will exceed the safe limits for a 3.5" shaft 54" in length.
Another poster ask, "in the olden days how did the old modified and comp cars turn 9,000 + RPM with most using some from of factory driveshaft?"
Just for conversation I suspect the on-line critical speed charts we find have a large window of cushion.
I look forward to comments.
Larry Woodfin 471W
