Old 06-10-2015, 05:34 AM   #1
Squirrell
Default BBC Flexplate.balance
Hi Guys , I have just finished a new engine , rotating assembly was balanced in the US and engine assembled in Australia. Flexplate says it is for an external balance engine, can I neutral balance the flexplate.and then fit it to the engine?. Or do I have to buy another flexplate?.
Thanks Squirrell.
Squirrell is offline   Reply With Quote
Old 06-10-2015, 09:32 PM   #2
Bill Baer
Default Re: BBC Flexplate.balance
Well if the rotating assembly was internally balanced you might get away with just removing the balance weight from the flex plate. Call the guys who balanced it.
However if your required to have an SFI flex plate at least in the US you cannot modify it, as to do so would render it illegal
Probably best to buy the correct flex plate.
