Old 06-06-2015, 09:39 PM   #1
Mike V
Default Tubeless tire pressure
I recently changed to tubeless slicks,Hoosier 29 x 9 (bias ply).The car is an automatic weighing 3300 pounds.I am still running 12.75 pounds of air.But after looking at this picture I think I need to raise the pressure.Any suggestions of where the pressure should be?
Mike V is offline   Reply With Quote
Old 06-06-2015, 11:19 PM   #2
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: Tubeless tire pressure
What size is the rim? J.R.
J.R. Haddad is offline   Reply With Quote
Old 06-06-2015, 11:39 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Tubeless tire pressure
I've heard pressures from 14 to 25+ lbs from 9" tire racers. Lot's of variables, but most seem to be in the high teen to low 20 range. I have Hoosier 9"X 30" Lightweight Radial Slicks at 21 lbs on a 10" rim, car weighing 3,540 and footbraking. Wider rims allow more pressure and radials seem to like a little more than bias ply. I fine-tuned it by watching if contact is being made all the way across the tread (may need less if not) or if rubber is being laid over the side (may need more).
LOCOMOTION Racing
Old 06-07-2015, 07:52 PM   #4
Mike V
They are 15 x 10 rims. The car is working great ,but I'm concerned about how safe it is.Thinking of going up 1/2 to 3/4 of a pound and see what happens.
Old 06-07-2015, 07:59 PM   #5
John Dinkel
Liked 263 Times in 68 Posts
Try 20 PSI. Don't be afraid of more pressure in the radials.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 06-07-2015, 08:20 PM   #6
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
I run 15x10 with 29.5x9 bias ply but a stick car. Never been above 15 lbs unless I want to spin. OP stated bias ply. Try 13 lbs and work up from there.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 06-07-2015, 09:16 PM   #7
J.R. Haddad
Bias ply and radials have nothing in common. Start at 20 lbs. with a 10
inch rim, and go UP from there.
Old 06-07-2015, 10:36 PM   #8
GTX JOHN
Same tire and wheel size on one of our bracket cars = 16 to 17 is where we
ended up. Seemed high for bias but lower pressure really tore up sidewall.
Our car is 3300 LB. with 1.5 to 60 Ft.
John Irving
741 Stock
741 Super Stock
Old 06-07-2015, 10:50 PM   #9
NOVALOU
What does the car usually 60' like? Definitely more pressure, the tire looks like it's trying to roll over itself.
I would up the pressure a bit, work towards 13-14lbs., and maybe make a shock adjustment if needed also.
I'm no expert though.
NOVALOU is offline   Reply With Quote
Old 06-07-2015, 11:34 PM   #10
Mike V
Usually low to mid 1.60's. I will have to up the pressure and mess with the rear shocks.I see a day of testing in my future. Thanks
