Old 06-02-2015, 11:15 AM   #1
Tgreen3724
Default BBC Spring Locator Cups Question?
running a BBC cast iron head (casting 188) with Comp 947 springs and in order to clear the rocker arms I need to reduce stack height by .045. To get my stack height back should I remove the locator cups completely and just run the springs on top of a .015 shim or should I machine .045 off of the bottom of the locator cups (leaving .015 of thickness). Without cups I have approx. .105 of clearance between the ID of the inner most spring and the od of the valve guide. I do not run seals so clearance between spring and seal is not needed. What are your all thoughts?
Tgreen3724 is offline   Reply With Quote
Old 06-02-2015, 02:02 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: BBC Spring Locator Cups Question?
To gain more clearance between retainer and rocker,are you planning on using a -.050 lock which reduces installed height and then removing spring seat or machining it to gain the .050 back in installed height?
If i was doing it and had the room to set spring installed height .050 less I would just put the -.050 lock on it and run more pressure.
If don't have the room,if head will locate spring take spring locators/seats out and use .015 shim.
Mike Taylor 3601
Old 06-02-2015, 02:59 PM   #3
TurboBuick6
Sounds like you have .560 guides. We do offer a .030" thick spring seat for those springs. Depending on installed height, you may be fine running the -.050" locks and our .030" tick ID locators.
TurboBuick6 is offline   Reply With Quote
Old 06-02-2015, 05:58 PM   #4
Tgreen3724
If I can reduce stack height by .045 then my distance to coil bind becomes .064 if I tried .030 I would only have .049 which wouldn't be enough. Thanks for the suggestion though
Old 06-03-2015, 09:46 AM   #5
TurboBuick6
No problem. I would like to say, you are way better off machining the heads. With the amount of ID and OD clearance you will have, I would not trust that spring on a flat shim. Too much movement available.
Old 06-05-2015, 07:48 AM   #6
Mike Taylor 3601
Don't cut spring pocket any deeper.
Mike Taylor 3601
