'65 Chevelle tunnel clearance
?#1&2..With a big block/PG combo,(in stock location) using a typical bolt-on tranny shield, will that clear a stock, original floorpan? Or am I gonna be the proud owner of a new Reid case?
?#3.. Did Chevy change the contours of the tunnel starting in 1967 when the TH 400 became avaiable behind the 396?
#4 Anyone know of an SFI approved 153 tooth flexplate for an externally balanced, 2-piece rear main BBC? My JW UltraBell doesn't seem to want to clear the 168 tooth flexplate. Anyone else experienced this?
Any help will be truly appreciated.
