Old 04-29-2015, 12:59 PM   #1
mykids
Liked 2 Times in 1 Post
Default BEST and EASIEST WAY TO INSTALL A 2 STEP
Would like to get a 2 step in our Stocker and not sure about a micro switch on the break or a pressure switch before the Line Loc what do you seasoned guy's have to say and Thank's in Advance for your input
mykids is offline   Reply With Quote
Old 04-29-2015, 02:40 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: BEST and EASIEST WAY TO INSTALL A 2 STEP
I have the Folk Race cars switch that is installed in the brake line. I think they call it "The Answer" I like it and seems to work good for me. Very easy to install and wire.
Old 04-29-2015, 02:45 PM   #3
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
I have both, I think its a personal preference. electric likely easier, and cheaper, especially with a under $10,000 stocker. When the Dakota was a stocker, it had the electric, switched it to pressure switch with super stock. Gremlin has electric.
Eric
Eric Merryfield 1883 STK
Old 04-29-2015, 03:09 PM   #4
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
I installed a transbrake button on my brake pedal and then installed a microswitch on my Turbo Action shifter so that the rev limiter is only active in 1st gear.
Thomas
NHRA 1959 D/SA
Cdncarnut is offline   Reply With Quote
