Old 04-28-2015, 11:30 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default Hurst 3 Speed Shifter For Metric Forward Pattern
To my knowledge I have never seen a Hurst shifter used for a forward pattern 3 speed especially a metric 200 application.......I know Turbo Action is the most used I have ever seen, but is there a defect or complication with a Hurst 3 speed for a metric three speed ????
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 04-28-2015, 12:19 PM   #2
CJ McDonald 9564
Liked 11 Times in 6 Posts
Default Re: Hurst 3 Speed Shifter For Metric Forward Pattern
It's very easy when making 2-3 shift to go all the way into neutral. They work fine with a reverse pattern.
CJ McDonald 9564 is offline   Reply With Quote
Old 04-28-2015, 12:57 PM   #3
Lou Jeffery
I run a Hurst quarterstick with a forward pattern Ford C4 without any issues.
Lou Jeffery is offline   Reply With Quote
Old 04-28-2015, 01:44 PM   #4
Rusty Davenport
Does the shifter not stop at a "bump" or "stop" gate or do you actually "place" it in 2-3 and actually push it past 3 by accident ???
Old 04-28-2015, 01:50 PM   #5
glen myers
glen myers's Avatar
Liked 2 Times in 2 Posts
Maybe Hurst can make a special "old guys" unit you can just put in "D"...
glen myers is offline   Reply With Quote
Old 04-28-2015, 01:58 PM   #6
Rusty Davenport
Thanks Glen you are so good with words :-), don't make me say it.
Old 04-28-2015, 02:01 PM   #7
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I use the TurboAction in the Camaro with a metric, but considering changing it out for a PPP shifter soon.
http://www.precisionperformance.com/home.htm
Rich Taylor
I/SA - 321
Old 04-28-2015, 02:01 PM   #8
Rusty Davenport
Do I read into that you have to "squeeze" the lever handle to make 2-3 ???
Old 04-28-2015, 03:26 PM   #9
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
Yes, mine is that way and you can shift past 3rd and into neutral. There is no detent in the shifter to stop it from doing that.
Jon Sarrett is offline   Reply With Quote
Old 04-29-2015, 07:51 AM   #10
Lou Jeffery
When shifting from 1 to 2 you just move the lever to the positive stop. When shifting 2 to 3 you squeeze the handle and move to the positive stop. If the driver does not pay attention and keep the handle squeezed through the 2 to 3 shift it could go to neutral. The handle being squeezed is what allows the lever to move to 3 and provide the positive stop.
