Old 04-15-2015, 02:02 PM   #1
JP Schuster
Default 327/275 HP Super Stock GT Combo: What Converter (stall)?
Hi guys,
Working on my Fourth Gen Camaro 327/275HP (299 adjusted HP) Q-jet combo. 1.98 Powerglide. 6.00 rear gear. 100 inch circumference radials.
Looking to run GT/EA-FA-GA
I'm not really looking for a brand recommendation, but I would like to know what converter stall you would like to see for the combo listed above. I know there's a lot more to it than just stall RPM, but I am just curious as to what something like this should call for.
While you're at it, how about a recommended 2-step RPM, shift RPM, and fallback RPM after the shift?
Sorry I don't have much information on the motor. Nothing crazy fast. Hoping to go .60 under in F trim.
Thanks,
JP
JP Schuster is offline   Reply With Quote
Old 04-15-2015, 03:11 PM   #2
Joe DeMarzo
Liked 121 Times in 11 Posts
Default Re: 327/275 HP GT Combo: What Converter (stall)?
You have a PM.
Joe DeMarzo 1317 STK
Old 04-15-2015, 04:08 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
J P, a builder tells me the 327 packages are in the 7" converter range and above 7000 stall [if you have the heads and cam to run about 8600 RPM]
Larry Woodfin 471W
Old 04-17-2015, 08:19 AM   #4
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
Thumbs up Re: 327/275 HP GT Combo: What Converter (stall)?
Correct, the 7" is the best way to go in the 283-327 S/S combos.
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
