Old 04-09-2015, 07:37 PM   #1
Ken Belanger
Default Dedenbear Stop help
I have a TS1 throtle stop with the C02 cylinder.
Do I understand this correctly.
I need to have the C02 on and 12 volts to have the blades open ?
This is the only way I can open my blades.
Thanks
Ken
Ken Belanger is offline   Reply With Quote
Old 04-10-2015, 12:04 AM   #2
powerstrokeace
Default Re: Dedenbear Stop help
yep thats right
Ace
powerstrokeace is offline   Reply With Quote
Old 05-24-2015, 06:32 PM   #3
H.A.A.C. Racing
H.A.A.C. Racing's Avatar
That's actually not true. Depending on how you have to polarity set up on your box you can either set it up so 12 volts closes the blades or opens the blades. I have mine set up so that when I turn on the air bottle it opens the blades without any power required. It's all in how you have your air lines to the solenoid and the mode you run in your box.
H.A.A.C. Racing is offline   Reply With Quote
