Old 04-09-2015, 05:22 AM   #1
Squirrell
Default Biondo 450
Hi Guys, when wiring in a Biondo Mega 450 do you run all the fuses that Biondo have on the wiring diagram ?. IE on the shifter , on the throttle stop and on the transbrake ?. Also can you run a circuit breaker instead of fuses ?.
Just switching from a KR Performance XTC 200 to the Biondo 450. The KR unit was quite old and we think it may have had a problem , just did not have time to find out if it was faulty.
Thanks for your help Patrick.
Squirrell is offline   Reply With Quote
