Lokar Anchor Tight trans dipstick
ANybody else have a hard time getting the right fluid level/reading on your lokar dipstick? This is the one that has the nut inside the pan. It seems like the tube is small and the end of the checker is big and all you do is drag fluid from the sides of the tube that you just put in and you get a full/over full reading when you know its not... I figure it will check it again after it has set and then you're only good for one attempt...hehe
Workin' on E/SA combo  3119 E/SA
