Old 03-26-2015, 10:25 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default Wideband output voltage.
Does anyone know the voltage formula for Innovate LM-1?
I am hooking it to a datalogger without a gage.
Thanks
Mike Graham is offline   Reply With Quote
Old 03-27-2015, 08:51 AM   #2
BUDDY JENSEN
Liked 38 Times in 9 Posts
Default Re: Wideband output voltage.
Mike
Call Felipe at innovate 714-372-5910 and he will walk you though it.
BUDDY JENSEN is offline   Reply With Quote
Old 03-27-2015, 09:25 AM   #3
boostedf22c
boostedf22c's Avatar
The LM-1 uses a Bosch LSU4.2 sensor.
The formula for converting voltage to AFR with that sensor (from my notes) is
AFR = 2.375 x output voltage + 7.3125
So if the output voltage is 2 volts that would be
2.375 x 2 + 7.3125 = 12.06 AFR (for example)
Carey Bales
316D DD/AT
www.racetactics.net
boostedf22c is offline   Reply With Quote
Old 03-27-2015, 10:28 PM   #4
Mike Graham
Thanks. That's what I needed
