Old 03-17-2015, 08:40 PM   #1
flash
Liked 6 Times in 5 Posts
Default weather station & antenna mounting?
I just bought a living quarters trailer,using a weather station with pager.I know how to install the rubber mounts for the weather station,I use a wall mounted usb port adaphter that has a small screw on cap when not in use.but the antenna has to be mounted either on the roof,or small L bracket they provide.I really don't like the idea of drilling a hole in the roof of this trailer to mount the antenna,but if you mount it on the L shape bracket,which stays there permantly-then you have to drill a hole somewhere to run cable which would look stupid running a black cable down the side of a white trailer.everybody is doing this,so am I missing something or just have not thought it out yet?instuctions say don't mount antenna near the weather station unit as well,-? any suggestions
flash is offline   Reply With Quote
Old 03-17-2015, 09:57 PM   #2
Ronnie Smith Jr
Ronnie Smith Jr's Avatar
Default Re: weather station & antenna mounting?
When I used my weather station I placed the antenna on the trailer roof as part of my weekend routine set-up. In other words, I removed it from the box at the beginning of the race weekend, placed it on the roof and then placed it in the box as I was packing up readying to depart.
For the wind gauge, etc, I found that the gauge would fit nicely on the end of a piece of galvanized wire conduit. As part of my packing/unpacking/setup routine, I would go through these steps each race. I bought an 8 foot galvanized conduit, set it up as a removable piece of equipment on the front of the trailer with removable conduit straps pre drilled into the trailer skin with the original trailer screws. The conduit end rested on the ground, secured by the straps in two locations while mounted to the front of the trailer and the weather station gauge affixed to the top of the conduit.
Never had any issues with the gauge/antenna etc due to weather. It was a consistent placement on the trailer each time.
Hope this helps and is the info you were searching for.
Ronnie Smith, Jr.
Ronnie Smith Jr is offline   Reply With Quote
Old 03-19-2015, 06:17 PM   #3
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
I drilled a hole in the roof of my LQ for the antenna, then used good quality caulking for metal. I mounted the antenna on the roof rail that overhangs the sidewall of the trailer. If you have the USB style weather station, the weather proof USB connector is a joke and way overpriced. There is a better application, as my original USB would still get moisture in it even with the cap installed going down the road. It stopped working during a race and I made a trip to Radio Shack to get a long cable to get by until replacing it. $90 for a USB cable is highway robbery when you can get something made for harsh environments at a 1/3 of the price.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-19-2015, 09:45 PM   #4
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Sean what do you suggest for harsh environments?
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 03-19-2015, 10:20 PM   #5
Sean Marconette
Hi Ross,
Here ya go. These guys helped me out and they are even located in Wichita, Ks. It will require the coupler, the cable and a cap. And still cheaper than the overpriced junk cable. You will also need another cable to go from the coupler to the laptop, I think its a male/male USB, thats a radio shack, or electronics store item and USB firewire also sells it too.
http://www.usbfirewire.com/usb-rugge...roof-zinc.html
USB Ruggedized / Waterproof A Male to B
PART# RR-211320-09-78
Size: 6ft (1981mm) $19.50
USB Ruggedized / Waterproof - Coupler
PART# RR-211300-30
Seal Cap (Optional)
PART# RR-1C543122M
Size: Seal Cap $7.95
Sean Marconette
84 Mustang
5060 SS/N
Old 03-19-2015, 11:36 PM   #6
Rat Raceway
Originally Posted by Sean Marconette View Post
Hi Ross,
PART# RR-211300-30
Seal Cap (Optional)
PART# RR-1C543122M
Thanks Sean
Looks like I will be replacing the plastic waterproof connectors I picked up a couple months ago. The above connectors look very nice and the price is not crazy.
Thanks Mr!
Ross Gregory
53 Top Dragster
